I've moved the cut-out and CU to a corner wall cupboard in my (being) renovated kitchen.
There will be 15 cables out of the top of the CU, running to the brick wall closing the open end of the corner cupboard. They then need to go up to the ceiling for distribution. I would like to embed the cables for the short run up to the ceiling rather than run them in PVC conduit in the corner above the wall cupboard. The wall in which the cables would be embedded is intended to be rendered, although it could as easily be plastered.
I can't fit 15 cables under standard capping within 150mm of the corner, although I could get a piece of 125mm wide capping custom pressed, which should do the trick. Is this a good plan, and is it OK for the bare cables just to run into the wall inside the cupboard from the CU or should they be in PVC conduit?
