- Joined
- 31 Aug 2004
- Messages
- 13
- Reaction score
- 0
- Country
Hi Folks
I have partly installed a 9.5kw shower. I've run 10mm T&E (via 45A DP Switch) to the cupboard where the consumer unit is. I need to upgrade to a new CU anyway so will be replacing my 8 way - wired fuse type box with a 12 way split load. ( I'll be getting a spark to do this bit).
I've buried the cable in plastic conduit in the bathroom wall, then through the ceiling and down into the cupboard. (Switch is positioned through the cupboard wall into the hallway outside the bathroom door). I was intending to surface mount the cable from the back of the switch, over the cupboard ceiling to the new CU.
From reading a few posts here, I'm concerned about the sizing of conduit for the 10mm cable, I'm using conduit that is a snug fit around the cable, and I've read a few posts suggesting that there may be a minimum "free space" required inside the conduit.
Q1 - Is there a specified conduit suitable for the section which I have buried in the wall ? (I've already tiled over it !!)
Q2 - Conduit size suitable for surface mounting in the cupboard ?
Q3 - The 12way CU kit I'm looking at comes with a 40A MCB, will I get away with this or need to buy a 45A. I know the arithmetic says a 40A will keep tripping but in reality, how often does the shower draw its full 41.3 A.
Many thanks for any advice available.
Andy
PS. Shower has been like this for 6 years - is this a record ?
Andy
