Whilst I'm sorting out my electrics in the bathroom I thought I would also run this one by you
My kitchen has a ring main all of it's own. Along with the usual sockets there is a waste disposer in the sink and a tumble dryer. If the tumble dryer has been used for any length of time running the waste disposer causes the RCD protecting the ring mains to trip. This problem will pass and everything will work normally after a few hours
Irritating
Strangely, if you unplug the waste disposer and run it through an extension lead from one of the other sockets also on the kitchen ring main it works fine.
The disposer and tumble dryer are close to each other and the obvious thought is some sort of warm damp air leakage from the dryer condensing somewhere in the ring, eg junction box and causing it to be a bit leaky so a bit more earth leakage from the disposer trips the RCD. Unfortunately there is absolutely nothing nearby this could happen to and looking at it after it's been used there is nothing even remotely damp that could be causing the problem.
Any bright ideas
Irritating
Any bright ideas
