Does anyone have experience of this product? Is it good/ bad / reliable and worthy of consideration.
I'm considering one for our staff bathroom, if it's a good thing and am wondering how you manage the potential for blowing the main fuse.
We have another 9kw appliance (an autoclave) which is run intermittently but the same situation could exist in a house with another electric shower in another bathroom.
I believe the body drier takes the feed and then feeds the shower in the bathroom so you can't use both at the same time. Would it be possible to use the "shower" feed to power the autoclave in a different room through a 45A switch or does that run foul of all sorts of regulations.
Alternatively is there a method of switching the power at the CU. My therapy pool has contactors in it's CU to have either the circulation pump or the air/water jet pumps on but not both.
It's not an area I am contemplating tacking just yet but would like to become educated and learn enough so that at least all of the first fix is done at the same time and we're not trying to retrofit missed wires
Our project started in May last year so we're not, I believe subject to the most recent regulations although I do like to install, or have installed , equipment as safely as possible. It will all be inspected and tested prior to use as part of my warrant.
All helpful comments are greatly appreciated.
