Hi all,
My first post on the forums and rather predictably it is to beg for your advice with an issue I have encountered with my heating system.
Firstly let me apologise for the length of this post, I want to give as much detail as possible.
I will try to summarise the issue along with what I have tried to resolve with no success.
This is a fairly new system installed approximately 6 years ago although I only moved into the property 2 months ago.
In my house I have a total of 9 radiators.
Of these 9 radiators, 6 of them heat perfectly to the point which they are too hot to touch. Perfect!
However, the other 3 radiators only heat to ‘luke’ warm and not enough to give off any heat and are as good as useless.
For the 3 affected radiators, I have replaced the temperature valve on the inlet and the lock shield on the outlet pipe. I have removed each radiator in turn from the wall and drained fully checking for blockages but both the water and the pipes are clear.
When the heating is turned on, the inlet pipes get very hot delivering the hot water without any issue. When I keep the outlet pipe disconnected the hot water coming from the inlet pipe flows straight into the radiators and out the other side so I have eliminated the flow coming into the radiator (which is hot) and the radiator itself as the problem.
When the other 6 working radiators are turned on you can instantly hear the flow of hot water entering the radiator and being circulated through and out the other side. With the 3 faulty radiators this sound of water flowing does not occur despite the inlet pipe heating up.
This affects 2 radiators downstairs and 1 radiator upstairs.
My system is run by a gas combi boiler which heats the water on demand in a sealed system. Apart from when replacing the water in the radiators I drained, the pressure sits at a constant 2 bar which I believe is correct from the FAQ. I really don't think this is causing any issue as the inlet pipe does deliver hot water (from feeling the inlet pipes are red hot) to all 3 problem radiators.
Without trying to lead any of the experts here towards the issue I certainly seem to think it resides in the flow of water through the outlet pipes. Its almost like the water can't flow through the outlet pipes, despite confirming 100% that they are completely open and replacing them with new lock shields.
I have also had the system professionally balanced whilst the above work was being carried out.
All 9 radiators have been bleed and I have tried shutting all radiators off leaving just the offending 3 but this has not helped.
Nothing has resulted in any progress ....
So please, can anyone help me solve this problem or give me anything to try or even what I should do next? I am desperate to get these radiators working again.
Kind regards,
Graeme
Kind regards,
Graeme
