I installed an extra power socket for my mother for a plasma tv. It was a simple enough job, just a spur from a socket located about 3m away.
The problem is, Iv noticed that even when the circuit is isolated by the main switch, and there is no power to the live conductors, I am getting a small amount of voltage in the neutral and earth wires. Its not a lot, its like getting a static shock, barely noticable. It is intermitant too, it seems to build up, after it has given you a small tingle or lit up the bulb in a low voltage test pen it goes. As the screws on the face plates are connected to the earth terminals, you can also get a small shock from them.
I am pretty confused by this. What could be casuing it? We are going to get an electrician to test it as Im only level 2 qualified, (currently studying level 3).
They realy need a full re-wire, as only the extention to the house built 3 years ago has up to date wiring etc, and is fed from a second c/u. The one which supplys the circuit in question is an mcb type board, but does not have any rcd protection.
