I’m replacing a suspended timber room floor due to rot and have uncovered the copper gas and CH pipes. I cannot recall seeing any supplementary bonding anywhere in the house, and have an opportunity to do so now. Should I link all three (gas/CH feed/CH return) together and is 4mm cable adequate?
The next project will be the kitchen and I suspect the incoming water pipe is not bonded either, especially as it is at the opposite end of the house to the consumer unit and there is a concrete floor in the way. Should the main bonding for this be run back to the consumer unit or is it adequate to install an earth rod under the dining room floor and run a 10mm cable from it to the incoming water pipe?
Finally, if I do install an earth rod, should I link the gas/CH pipes to it as well?
TIA
Mike
PS I’ve also discovered the source of the ‘damp’ smell in the room – a joint in the gas pipe had never been soldered when installed 20+ years ago and was held together by flux only!
TIA
Mike
