This is the only boiler that has a pre-mix burner and is non-condensing.
That shows that you dont work on boilers yourself!
Try thinking about Powermaxes! Or in your case start looking them up on the internet!
Tony
Tony
Tony
You may be right. The old IMM Powermaxes I think were pre-mix. About the only other one then. The Powermax is a floor standing unit, while Response is a wall model. The current Powermaxes are condensing.
You are right I do not fix boilers day to day - I leave that to others to change the pumps, as I am too valuable to be used on menial tasks. But I know how they work and in detail too. My advice to you is not to get involved in installations as you are clearly out of your depth.
The way to test rumbling air gas problems is to partialy cover the venturi to restrict air the rumbling should stop
sticking pipes, boilers and rads on walls isn't difficult bigbullshit.
You are right I do not repair or install boilers day to day - I leave that to others, as I am too valuable to be used on menial tasks. But I know how they work and in detail too.
You clearly know little of installation.
TO THE MODS will you please ban this man as he is clearly contravening forum rules.
