Hello,
My Grannies boiler is having a slight problem at the moment, when the heating is on the pressure goes all the way to just before 3 bar, the pressure relief valve is not lifted.
I went to check up and checked the filled loop is closed, then I bled water out of a radiator until the pressure was back to 1.5 bar.
I can't really give you a proper problem description because I only went to release the pressure in the fear of the PRV being lifted.
The heating and hot water works perfectly.
What is causing this severe pressure rise?
