Hi Guys
I'm trying to upgrade my central heating control unit to one that allows me to turn the heating on without the hotwater. Currently I have one that only allows me to have the hot water on only or the hot water and heating (can have them timed also using the dial), there are three wires running into this unit if this helps?
I'm not 100% sure what type of system I have so I'll describe it to see if anyone can tell me:
Downstairs:
I have a gas fire/back boiler and the old fashioned heating controller on the wall.
Upstairs:
I have a large hot water tank in the bedroom upstairs, the tank is insulated and there's a plastic tank full of cold water above it, this tank has a ball cock on it and fills up with cold water when I run the hot tap. There's a pump next to the hot water tank (the type with the big screw in the centre).
If anyone can tell me what I need to change to have heating only it would greatly appreciated as I'm only home every other day and it costs me a fortune to heat the place as a result.
Many Thanks
Tim
Downstairs:
Upstairs:
Many Thanks
Tim
