We have an old victorian tenement flat and are in the middle of having out flat renovated and at the moment the plumbers are in. I prepared the building warrant drawing and got the building warrant myself, and when the plumbers started work I gave them several copies of the drawing and hung one on the wall to make sure they could refer to it when needed.
It's quite obvious they are not following it as there are a few things wrong, but one thing I am a bit worried about. Building control would not allow me to run the condensate drainage indoors because it meant notching the joist tops. So I moved it on the drawing to show it going through the wall and along the outside wall to join into the svp. Now they have ignored this and run it inside. One of the joists is heavily notched. In fact it looks more like its been hacked away with drill and a flat drill bit.
The joist is about 240mm high by about 75mm wide. On on side it is notched about 30mm deep, sloping to about 80mm deep on the other side. Building regs state here that a notch is allowed to 1/8th of the joist height, which would be 30mm. The joist span is about 5500mm.
Is this dangerous? Should I be looking to have it repaired? Should I be shouting at the plumbers?
