Many thanks
I have measured all rooms /rads and taken a pic of the boiler for good measure. I can’t find the exact model of boiler on the net for specs, only what I assume is a newer version?
I have a vented, gravity fed oil fired central heating system.
The house is constructed of brick /slate /stone and anything else I thing that was lying around. Oddly the walls are approx 3ft thick downstairs but taper as they travel up. Not sure what the reason for this is. The walls in the upstairs bathroom are only 18 inches thick. There obviously isn’t a cavity. All internal walls are brick. The front elevation has UPC double glazing, the rear has wooden double glazing, and it’s crap!
The loft has 20cm of insulation in two runs of 10cm at 90degrees to each other.
The room dimensions and rads are as follows.
Lounge (with operational open fire) 12 x 12 - 800 x 600 double rad – 4853 BTU
Hall 28 x 6 1200 x 600 double rad – 7280 BTU
Kids Lounge 12 x 12 2100 x 750 single rad – 5000 BTU
Kitchen 12 x 12 1100 x 400 single rad 1600 BTU
Dining room 12 x 12 1100 x 550 double rad 5288 BTU
Master bed 13 x 13 1740 x 750 single rad 3330 BTU
Bed 2 13 x 13 2300 x 600 single rad 4995 BTU
Bed 3 13 x 13 1600 x 600 single rad 3330 BTU
Bed 4 8 x 6 No rad
Landing No rad
Main Bathroom 8 x 10 800 x 600 double rad 4853 BTU
Separate WC 10 x 4 No rad
Total BTU - 40529
EDIT: All ceilings are approx 8ft high.
Kids lounge, Master and Bed 3 have sealed up fireplaces. The downstairs hall has open stairs off to the upstairs landing.
The boiler is an oil fired Worcester Danesmoor 15 / 19 . I have no idea of its power output, and would guess at an age of 15 – 20 years.
Hope that helps.
