Maths Question
5 Aug 2006
Heres one for you all.
I have a VERY heavy base used to hold up a table umbrella for when its sunny. The base has a round hole for the umbrella to lock into.
I want to use this base as part of a bird feeder, as it wont be blown over the place etc.
Is there a way to work out what size of square wood would fit in a round hole if I knew the diameter of the hole????
Ie if the diameter was 10cm, then the piece of wood couldnt bebigger than 6cm x 6cm.
I think you can do the following:-
Square the diameter of the circle (so 10cm dia squared would equal 100)
Divide this by two ( = 50)
And then find the square root of this (=7.07)
Square piece of wood 7.07cm x 7.07cm would fit inside a 10cm dia hole.
I'm pretty sure thats correct??
Using Pythagoras, the diameter of the hole is the hypotenuse of a triangle with two other equal sides - which are the length of the sides of the square timber.
So square the diameter, then divide this by 8 to get the length of the side of the triangle/side of the timber
Cheers all for the help.
MY GF however thinks if i measure from the left top corner to the bottom right corner (cross section of wood), this should be equal to the diameter of the hole, so i would buy a pice of wood with a slightly shorter cross-section that the diamter of the hole.
Is she right???
How about a slightly oversized piece of wood that is slightly tapered ?
So that's 100/8 = 12.5: uhurrrrrrr :roll: somehow, you've made a side longer than the hypotenuse teehee.
no good getting a bit of wood that just fits in you need a bigger contact area
the small contact area of a corner will soon compress and loosen off causing it to lean or move
in this instance a 3" post at 76mm would be perfect by the time youve wittled away the corners to fit you will have around a 10mm contact area that will be less likly to cause problems
Throw the base away and just make a cross foot out of timber. Oh and while you're at it.... give your Doris a back hander for speaking without being spoken to. :wink:
