i have discovered my mechanical room stat is misreading temperature by 3 degrees, so when the room is actually 20 degrees the stat is at 17 degrees.
as in the title, are there any digital stats that only requre a battery and have 2 terminals, common and Y1...i.e so i can have switched live only, as per my old mechanical one.
preferably under 20 quid too?
this is the reason i was thinking my heating was not getting hot enough! i have also measured my hot water temp and its only 55 degrees. so my problems all lead to the stat
