Just putting in a new shower myself and have the LABC coming round for a cuppa before i go ahead.
8.5kw. NO room on the existing board. So going for dedicated mini shower cu with 40amp RCD and 40amp mcb.
100amp main fuse. i am coming from meter into Henley. then 25mm tails to existing CU and 25mm tails to new CU. Shower is 5 meters away so using 10mm t&e to shower via a DP cord switch.
Gas is bonded but water is not so will do this in 10mm and earth clamp and run all the way back to the MET block. Stop cock is 18 meters away.. oh joy.
The extraneous conductive parts in the bathroom are also not bonded so using 4mm with earth clamps starting at radiator, toilet cold feed, hot and cold on basin and tub and ending up in the earth of the shower or the DP switch.
Just checking this is ok depends on if i give the LABC guy a tesc0 value borbon with his cuppa or a foxes.
look forward to hearing from you
many thanks
atm
many thanks
atm
