What's the answer bolo, your dead when l see you
Let the width of the river = W. When they meet at time t, boat A is 650 from the bank and boat B is (W-650) from the opposite bank.
W = 1300
I think the width of river is 1300m and it has cost me a a few hours kip in the process. Bolo I can't believe this is for a 12 year old - madness - enough to turn any kid off maths.
I posted the answer on page 2. I didn't explain very well so I'll try again.
If we call the width of the river x, then when they first meet one boat has done (x-650)m and the other has done 650m. So the ratio of the distances travelled is one divided by the other, which is (x-650)/650.
When they meet on the way back then the first has done, in total (x-350)+x and the other 350+x, which gives a ratio of ((x-350)+x)/(350+x).
Those two ratios must be equal*, so you end up with an equation with one unknown which can be solved to give x = 1600m.
*I'm not very good at explaining things and am struggling to write why the 2 ratios must be equal. Imagine for the sake of it that one boat goes twice as fast as the other. When they first meet the faster one will have gone twice as far. When they meet on the way back, because they have each travelled for the same amount of time, the faster one must have still gone twice as far. It doesn't matter that they each paused for 10 minutes, they had still both travelled for the same amount of time when they met.
If anyone understands the explanation and can word it better for me please help.
I've searched the topic, especially the first post. I've looked down the back of the sofa. Heck, I've even looked in the least used compartment in the fridge, but I can't find anything that supports your assertion that the slower boat covers 650m from the port to the first meeting point.The slower ferry has covered 650m in that single time unit from it's starting dock.
Son says that this part is quite easy. If the slower boat travels 650m from its starting point before meeting the faster one, it stands to reason, because the other boat is faster, the slower boat will travel even less distance, ie 350m, before meeting up with the faster one on its return journey.![]()
He also tells me that the right answer has been posted above but wont say which it is
What's the answer bolo, your dead when l see you![]()
Ever get the feeling this is a wind up ?![]()
That's the laughter of a hysterical madman, surely?
I can't fault this, so it must be right.If we call the width of the river x, then when they first meet one boat has done (x-650)m and the other has done 650m. So the ratio of the distances travelled is one divided by the other, which is (x-650)/650.
Those two ratios must be equal, so you end up with an equation with one unknown which can be solved to give x = 1600m.
It is 1000mts wide.
Quite right. The vital piece of information, that I initially thought was missing, was there all along. This was the relative speed of the boats.There's something about the way the question is worded that makes you (or at least me) think that the boats have been travelling for a different ammount of time by the time they meet, but of course, they haven't. It is the same time elapsed for both since first setting off, and as they both had a ten minute stop-over, they have both been travelling for the same ammount of time.
