Dulux magic white rich matt on new skim
15 Dec 2008
London
Hi
I had artex in on my bathroom ceiling which i got a plasterer to remedy providing a nice smooth surface.
This was 2 weeks ago and it's perfectly dry now.
Can I just stick 2 coats of Dulux Magic White Rich Matt (goes on pink, dries white) on and be done or does it need plaster sealer etc first?
Cheers!
Please read the forum rules, don’t double post as it causes confusion & really isn’t necessary. :wink:
This from Dulux:
'. Seal new, bare and porous surfaces, including previously unpainted patterned textured ceiling coatings, new buildings that have a plasterboard finish and wallcoverings that are suitable for painting (not vinyls or washables).
For best results, use Dulux Plaster Sealer.
This from Dulux:
Yes but they would say that wouldn't they; I don’t know but wonder how much "Dulux Plaster Sealer" costs! :lol:
Don't waste your money mate on the pink stuff.
B&Q have 10L of Crown Brilliant White Matt at the moment for £10.
First you need to seal the plaster with watered down paint use the above
paint mixed 50-50 with water and roller this on ONCE.
It will look crap but this is only a mist coat and will provide a perfect foundation for the next step
Once completely dry after around 4 hours
The second coat should be applied use the above paint watered down 80-20.
Roll this over once.
Final coat is non thinned paint and I normally do 2 coats.
The best tip I can give is use a quality roller and let all coats dry completely before applying the next coat.
Stand back and enjoy a nice cuppa.
Long time now but i used to be a painter and decorator (20 years ago),i worked on hundreds of jobs with new plaster,all we did was water down the first coat of emulsion,then paint and fill as normal,never any problems,don`t need any expensive sealers or gimmicky paints,just work in a methodical manner and you won`t miss any.
Planemad and Simonpolly hit the nail on the head.
Don't waste your money on the must use this and that products.
All I will add is that if this is a bathroom or kitchen I would use silk or semi silk paint for the final coat due to exposure to dampness.
