anyone tell if compression joints can be used on gas please
what about behind kitchen cupboards
do you no the answer to my question because i have had a so called corgi man in to do my own new cooker move and he said its ok to put compression behind cupbords because they are not a permanant fixture
Bit of a grey area this IMHO. I treat kitchen units the same as I treat floorboards - both can be removed but not easily and compression fittings are not allowed under floorboards. If the fittings can be accessed from within the cupboard then no problems but if they are behind the cupboard backpanel
Eh?? I think you will find that as long as the compression joint is accessible then its legal. I fail to see the point of being abusive, especially when his comment about accessibilty is correct.....
