gas pipe work (compression joints)
If you are putting in gas pipes you should be RGI, in which case you'd know the answer.
The qick answer is yes.......but only if the joints comply with regs and as twgas has said if you were qualified to do so you'd know.......don't break the law, call a qualified engineer
I smell a rat here! Judging by the OP's previous posts he has had three different boilers since September.
Could be a landlord I suppose. :roll:
no not at all. I think this is a great site and have told family and friends and i ask questions on there behalf, but thank-you for your consern.
Andy
do you no the answer to my question because i have had a so called corgi man in to do my own new cooker move and he said its ok to put compression behind cupbords because they are not a permanant fixture.
So called gas fitter knows more than you do. If the connection to your cooker is a bayonet fitting and directly behind the cooker and will not come into contact with any heat, then it`s all good. I believe the existing connection should be betwen 500mm and 700mm with allowances for worktops either side, 50mm I think, can`t be ar*sed loking it up, make sure your room housing the cooker is of adequate size, if not you will need purpose provided ventilation.. :lol:
Bit of a grey area this IMHO. I treat kitchen units the same as I treat floorboards - both can be removed but not easily and compression fittings are not allowed under floorboards. If the fittings can be accessed from within the cupboard then no problems but if they are behind the cupboard backpanel.................
the best one is, if your kitchen dont have an openable window you cant have a cooker in there no matter how big the room is or how much ventilation you have.
Good job you don`t make the Gas Regs then... :wink: the law is there to stop D * ickheads lke you from joining pipes together in the wall or beneath floors, then finding a leak and being unable to access the joint. :roll:
Eh?? I think you will find that as long as the compression joint is accessible then its legal. I fail to see the point of being abusive, especially when his comment about accessibilty is correct.....
I`ll think you`ll find that you and the poster are not gas fitters, :wink:
he he :)
if you can access the joint then cause you can use compression, we dont do though even if it is accessible as if you think about it, eveything is eventually accessible whether you just have to screw a panel off to get to it or rip a whole kithcen out and chop the wall out.
a soldered joint is definately the way forward . . . soldered by a corgi installer . .. . .
