I'ts not sarcasm, its frustration.
The cylinder that you were initially holding is the correct way up - you know that, as it came out of the door that way. If I'd asked for an upside down photo, I'd have requested one.
I've advised the cylinder is faulty a couple of posts back, and yet you are still debating this. If I hadn't come onto this thread, where would you be at the moment - still scratching around for the answer.
Good luck with finding a replacement cylinder, and I hope you've measured it correctly otherwise it will either be too long or too short for the door. BTW the DIY sheds only carry a limited range of cylinder sizes, and you are likely to pay well over the odds.
