Not ideal isar 24he
  • Thread starter Thread starter hav it
  • Start date Start date
H
hav it
Hello, Had to re install an isar today, due to boiler being removed from new build 4mths ago due to theft in other houses. Guess what boiler wont fire. It flashing h4, what i think is flue temp sencor, pump runs constant but will not reset. good old ideal
H4 is ahigh overheat code usually get this if the water isn't circulating properly has the air vent screw been undone?
Check the pumps spinning and make sure heating iso valves are open.
valves open and pump running. Is h4 not flue temp sencor there are 2 location depending on model, mine just sits into main hx
Following the MI's fault finding, it does indeed point to the flue thermistor.
Check ntc resistance values as per instructions.
I have also had this caused by the usual condensate trap/sump blocked :shock: God knows why though :?
quite possibly true but the only time i've seen it was when boiler overheated due to poor circulation - don't ask!!!
yeah i know where your coming from but boiler not fired so no heat.
