Hi
I was about to fit a frost stat and now have a problem with my cylinder stat!
for some reason it is not heating up the water in the cylinder. the programmer is on and the heating works fine as normal.
i was presuming the cylinder stat was stuck and not claling for heat. but am a little confused now after reading the honewelluk.com wiring guide website.
it said - assume the cylinder stat is faulty only is terminal c (common) is not live when calling for hot water. - now i have used a multi meter before and can do so again, BUT I thought that the Common (C) terminal would be live and the number 1 (CALL) terminal, which is also in the same terminal block as the orange from the 3 port and the s/live from the pump and boiler, would NOT be live (thus the stat sticking in the closed/satisfied position) - can anyone please clarify this so I guarantee my cylinder stat is faulty, before buying and fitting a new one?
Thanks in advance all.
