Hi all,
I am planning to extend my main ring into a new "box room" home office. As there are no existing electrics in the room and the new sockets aren't physically between 2 sockets in a circuit I need to break into the nearest socket in an adjoining room instead. This will necessarily involve the use of a junction box, although I know it is not ideal.
To briefly explain the extension, I am planning to do the following (following the circuit round, not in chronological order!):
1) Disconnect one of the cables from socket on the ring circuit. Connect it to a junction box.
2) Run a cable from this existing socket to the two new sockets and back again into the junction box to complete the radial circuit.
Ideally, I want this junction box to be as accessible as possible, so I am planning on putting in a flush mounting box where the cables are connected via a choc block. I would then fit a blanking plate so that it could be accessed at any time. My questions are :
1) Is this set-up OK?
2) Is there any guideline saying where the junction box can or can't be located?
Thanks in advance.
Thanks in advance.
