Mapei flexi floor adhesive o ply
15 Dec 2007
Yorkshire
hi
will i have to prime the ply before i tile using the mapei flexy powdered adhesive its 14mm. exterior i have put down
thnks
i am just about to start laying the floor tiles with mapei flexi i just wondered how long you have to "juggle" and cut out the rad pipes holes it says that they are set in 15 minutes that is a bit quick for me can anyone advise thanks
dry cut it fella
Listen to Jef. Once you put the tile in place you want to be leaving it there. If you make your cuts and dry lay your tiles, you'll know that it'll be ok before you even start mixing any adhesive. This way you won't need to move any tiles you have laid.
[quote="gcol";p="1178324
I'll be doing this tomorrow - just to clarify.....is this Mapei Keraflex that is being talked about here? want to make sure im buying the right stuff
CB
There is no Mapei adhesive called "flexi" so I'd assume he means Keraflex.
CB
cheers shifty
i thought that was the case and went with the karaflex. seeme alright when i put it down so i guess time will tell
Tristan
