night storage heater
23 Dec 2008
Sussex
can anyone help please
my brothers night storage heater doesnt work and there isnt a time switch so that i can turn the power on for it in the day so i can test if the power is going through the heater etc....
there is the radio transmitter for the economy 7 near the c/u but i cant find any test switch...
theres probably an easy way and i dont fancy going round late at night
hope this makes sense
Turn the power off first (don't assume that the timer is correct). Take the heater front panel off (usually two screws at the bottom). Look at the workings of the controls and see if there's a small button that can be pushed in to reset the thermal cutout. This is usually the problem.
Otherwise use a multimeter to check continuity of the fuse, the elements and the circuit going back to the off peak board.
If you feel you are competant to do so !
thanks for help.. the switched fused spur has a neon on it that does come on so i will look for the thermal cut out switch first thanks
Un-wire the flex from the storage heater and replace with a plug, plug it into an extension lead fed from the 24/7 supply, and wait....
Happy days :)
If it's an older model(still a lot around)the thermal was a meltable link.with cover off look at the top of heater it should look like a grey/silver fuse.
