I need a to get some estimates for the wiring of a new garage, but I want to check what might me needed before I do.
The house is wiring is TT single phase and was been installed about 15 years ago.
The garage is 35m away from the CU.
I was thinking of a small radial and lights.
What I think needs to be quoted for is
Installing of 4mm or 6mm SWA earthed only at the house
A new ground spike installing at the garage
A 40A isolator without rcd on the incoming supply to protect the cable
A cu in the garage with a 32A mcb going to
6A mcb - lighting
16A rcbo - sockets
The cabling in the garage to be done radial with conduit or trunking and metal clad sockets.
The garage also has a metal outside tap supplied by a plastic pipe, this may need earth bonding to?
The supply can be isolated at the meter.
If the trench is already dug will this job need about 2 days labour?
Is there anything else required?
6A mcb - lighting
16A rcbo - sockets
