S
sparkyspike
so it looks like the earth spike is going to have to do....
Ah, now it's getting clearer. If you have a spike and a confirmed TT supply then you need to sort out the earth cables in the supply head. Best thing to do is to test the cables and sort out which is your main earth cable and which are bonding cables etc and whether the continuity is sufficient.
You can request a PME terminal - whether it is available or not is another thing - but it should be fairly straightforward to find out. When you call the supplier, ask for the number of the depot concerned - you can talk to an engineer directly that way.
Once you've got the PME terminal, you can connect your 16mm (if that's what you need) to the first CU and then from there you can run a cable to CU number two. If you're stuck with TT, then you can fit a MET and run everything from there.
