S
Simonbeasley1
- What fitting?
I have to pipe up new appliances Friday from a new meter position. Southern Electric Have already re positioned the semi recessed Meter box and connected to the existing incoming Gas Main.
The meter is being connecnted on Friday and i have to be around to connect to the new appliances. The pipework feeding the appliances will be in 28mm Copper pipe. The fitting on the side of the meter box is only 3/4 Female.
How do i go about increasing it fit onto The new 28mm Gas Pipe??? Surely can't be to use a variety of bushes and BSP fittings to eventually get to 28mm - does the 3/4 meter adaptor come in 1" size?
I know this is a daft question but never done a semi recessed box. Normally i would just solder 28mm coupling directly to the meter union.
Thanks for your help in advance
Simon
Simon
