D
dextrous
i said this... said:If i may, pic no. P1010360 shows a wall that looks like its been plastered by Stevie Wonder! If that was the level of craftsmanship your palsterers were capable of then i'd be more concernced about that.
I'd say that's usually cos you've HAD a shoddy plasterer in the 1st place.dextrous said:True it could have been better in parts, but I've yet to see a plastered wall that's perfectly finished. That's partly the purpose of a mist coat, to identify any rough spots to enable fine-fill and rubbing smooth.
And i agree its what i'd use the mist-coat for when i plaster, but with pro's its nearly always spot on, with the mist-coat then being applied with its proper purpose in mind......moisture fixing.
Have only seen the results of 20 or so different pro's finishes in my time in different customers houses, only one of which required no further work. That's a lot of shoddy plasterers then!
