Hi -
I want to fit a water softener into a standard kitchen cupboard adjacent to the sink due to lack of space directly beneath the sink.
Access to waste, overflow and power is ok. Rising main to loft header tank is more difficult as it runs horizontally behind the drylining in parallel with a return hot feed. Access is limited as I'll be working under granite worksurface and "through" a 500mm base unit.
If I remove a piece of drylining 300mm by 88mm to expose the pipes, how would you recommend cutting the cold pipe (hacksaw?) and fitting the valves ? I was hoping to slot the valves in line in a 9 inch gap cut in the pipe with valve bases against the brick.
Does this make sense or would you solder elbows to bring the pipe out from the wall for more access and clearance? I've got fairly high pressure and want very secure and well supported joints.
