- Joined
- 27 Jan 2008
- Messages
- 29,340
- Reaction score
- 3,608
- Location
- Country
I have had wires just sticking through the wall for my TV for years and I decided to clean them up. Sunk in the 35mm box and feed through wires.
2 x LNB (only one used at moment) plus one return to loft which then feeds a 4 way splitter booster.
I saw a nice Labgear face plate with 4 connections 2 x F connector and 2 x IEC (f) only required 1 x IEC but not really a problem.
However once I opened it up there are only two connections. One to F connector marked SAT 2 and one to other three.
I will guess some loft box is designed to combine DAB, UHF and SAT all into one cable and there is a band pass filter to split them again.
Marked as PSW241 it is likely that this
will do the job better but there was nothing shown with this socket
to show it had a built in filter. Does anyone know what type the first is please?
