any idea why there should be a sort of cracking sound from an expension vessel on an unvented cylinder?
makes the noise as the hot taps are tuned on & off
dunno about cracking. But you can get a vibration noise if the dynamic pressure is significantly lower than the expansion vessel pressure. The solution is to measure the dynamic pressure at the taps then set the expansion vessel pressure to match.
