Hi
I have recently fitted a new staircase and removed the old understairs cupboard, I want to fit a wall socket on the new exposed wall, the problem i have is that the other side of the wall is the down stairs toilet so no power in there, then the other side is the living room and a socket is available to run a spur, but can i run one horizontal above the skirting board and up in to a new socket, or should i channel out the concrete floor to run it from the living room?
Any ideas on what is safe, i will know where the wire is but the next ocupant may not, and i thought you had to come up from the floor or down from the ceiling, but in this case its impossible.....
