I'm painting the exterior woodwork on our porch which was previously stained or possibly varnished a teak colour. The porch looks about 15 years old so this was probably a factory finish but is now very weathered.
I've given it two coats of white water-based Dulux weathershield exterior undercoat and intended to use exterior satin Weathershield as the top coat. However there is a yellow stain seeping through the undercoat. It's not coming from knots. In fact it seems to come mostly from the joints and filled holes so it may be coming from a filler rather than the wood itself.
Since it's seeping through a water-based undercoat should I try an oil-based one? And if so, what should I do to prepare the current surface and can I then use the water-based satin topcoat or do I need to use an oil-based one instead?
Many thanks
Liz
Many thanks
Liz
