D
dextrous
Am having services installed for my log cabin (approx 20m from main house and thus 30m from consumer unit).
The original specifications were to run 4.0mm armoured cable to the garage with 4 way RCD consumer unit within the cabin to supply rings and lights for this and the adjacent garage, and a 65A isolation switch (with new tails to it) adjacent to the main house CU.
As the water pipes being run to the cabin (hot and cold) have been insulated for their entire length, and run within 110mm drainage pipe, the contractor has discussed the option of using 6mm (non-armoured) t&e cable through this ducting instead. Obviously, any variation in the cost of materials used will be accounted for, so this isn't a way of him increasing his profit, and I'm not worried about any extra cost for using SWA should that be more appropriate in your opinion..
BCO will be inspecting the building work (and hence the cabling run) and one of his electricians will make the final connection and thus certify.
So, finally, and at last (I hear you say) are there any problems with doing this or any advantages/disadvantages either way?
