Crumbling bricks due to damp?
11 Jul 2009
London
Hi there,
I have recently moved into a Victorian Terraced housed with a layout of kitchen - then living room, which has a an understairs cupboard. The walls of this cupboard are exposed brick work painted with white paint.
A few of the bricks on the back wall are really crumbling - the paint has come away, along with about a 1/3 of the brick. If you touch it, it crumbles. Strangely bricks that are just next to the dodgy bricks are absolutely fine - amateur photo attached!
Any help gratefully received, as I'm not sure if this serious e.g. leak or rising damp, or just age. Before I start pulling up floor boards etc. I'd love to get some advice.
Spalling and perishing of soft bricks is common amongst older properties.
Once the protective face of the brick has worn away, or if the mortar has broken down, then water can penetrate the brick which is fatal in sub zero weather.
Also, any sulphates present within the masonry will have a detrimental effect, should the masonry become wet or excessively damp.
Not inside the cupboard though!
The OP needs to check externally for defective pointing or bricks
BTW, Nose, that was post 10001, congrats
Thanks for the replies, I can't check the external wall as it's the joining wall with my neighbour who is very elderly.
Is there anything else I can do?
Knock the loose stuff off and gob the bricks up with a sharp sand mortar with PVA added. That will do for another 100 years
