I'm fitting a power shower over my bath. I am also fitting a 50 gallon header tank in the attic. My query is, would I be able to fit the pump in the airing cupboard, below the hot water cylinder, and then return the both pipes, cold dropped from header tank, up into the attic and across to the bathroom? I can then drop the pipes down the bathroom wall to the shower unit. My header tank is raised about 300mm above the attic floor.
I thought of putting the pump in the attic, but there may be a problem with unequal pressure, as the hot water pipe will have to rise from the cylinder.
Any suggestions, please,
Thanks,
Poet.
Thanks,
Poet.
