PLEASE HELP,fitted tap ok but i cannot tighten the nut underneath,i bought a monoblock spanner set from screwfix but don't fit
the set had 9mm 11mm 13mm 15mm i think i need a 10mm,but i need a spanner that will fit under the nut and through the screw,similar to a spark plug remover
i think the OP means a socket wont fit cause the threaded screw passes through the bolt stopping the socket reaching the nut, i use a spanner fitted onto the nut at an angle, it is a bit fiddly as you cant turn the spanner much but a little patience gets you therethe set had 9mm 11mm 13mm 15mm i think i need a 10mm,but i need a spanner that will fit under the nut and through the screw,similar to a spark plug remover
Huh?
i think the OP means a socket wont fit cause the threaded screw passes through the bolt stopping the socket reaching the nut,the set had 9mm 11mm 13mm 15mm i think i need a 10mm,but i need a spanner that will fit under the nut and through the screw,similar to a spark plug remover
Huh?
you will never get in with a hacksaw once the threaded bar is fitted into the tap, it would need to be done before the tap was fitted, suppose i am thinking of socket rather than box key, as long as box key is longer than threaded rod it should be easy peasy so i dont know why the OP cant tighten iti think the OP means a socket wont fit cause the threaded screw passes through the bolt stopping the socket reaching the nut,the set had 9mm 11mm 13mm 15mm i think i need a 10mm,but i need a spanner that will fit under the nut and through the screw,similar to a spark plug remover
Huh?
Bit odd if that's the case since the shaft of the box spanner will be nearly as wide or wider than the hexagonal head of the nut that goes over the threaded rod. But if it is true, then shorten the threaded screw with a hacksaw.
you will never get in with a hacksaw once the threaded bar is fitted into the tap, it would need to be done before the tap was fitted, suppose i am thinking of socket rather than box key, as long as box key is longer than threaded rod it should be easy peasy so i dont know why the OP cant tighten it![]()
Send me a private message with your address in and I'll post you a 10mm box spanner on loan.the set had 9mm 11mm 13mm 15mm i think i need a 10mm,but i need a spanner that will fit under the nut and through the screw,similar to a spark plug remover
I have most sizes - which one do you need?you got a decent core drill you could lend me?
