can it really be a borrowed neutral?
The OP can have one light on, and the second trips the RCD.
If you take the lowest likely power bulb, eg 9W, then that's 300 mA, so should be 10x the current required to trip an RCD if it's using the wrong neutral.
what about a neutral-earth fault with a resistance of a few ohms? that would probably do it. needs an IR test i think.
