One.
The mains out is not live till it is connected to the mains in.
Lighting not usually a ring in domestic .
Do you mean connected up?
You should have 240v on the 3 which are joined (loop) and possibly on the switch return which could be blue with a brown sleeve or brown.
Once they are connected, yes, both browns are live, as is the feed to the switch. But disconnected, you will only have one live wire.![]()
Yes connected up - so 3 cables mains in , 3 cables mains out and 3 cables from the switch
I thought 2 as the mains in would be 240 v from the CU and I thought the mains out would also be 240 as it flows out
cheers
Indeed, and topics like this stay on here FOREVER![]()
