Cavity wall gap- maximum size for insulation grant
17 Nov 2007
Southampton
I’ve just had an “energy assessor” round to measure up for cavity wall and loft insulation. Apparently, one of my cavities (the end wall) is 83 mm, and the other 2 are 62mm. The 62mm cavities are fine, but the 83mm cavity isn’t covered by a grant (I applied through the Tesco £198 scheme), as this only covers up to 80mm. I would therefore have to pay an additional amount to cover to extra 3mm. Is this restriction normal or should I look at another scheme?
CD
How was the cavity measured?
From what I saw, and he clearly wasn't too keen on being accompanied on his visit, he drilled the outer wall then inserted a wire rod with tape on it (presumably predetermined marks or something), withdrew the rod then measured some distance on the rod. Is this a normal way?
Sounds like a crafty cop-out to me.
I appreciate these companies have to have a cut-off point, but, as woodster has said, how are they justifying their measuring?
I think the "surveyor" needs his cavity measuring :twisted: :P :lol:
Sounds like it to me as well. Also forgot to mention that the 83mm cavity was the end wall and subsequently the biggest wall- as it has the, erm, pointy bit. Is it called the gable end?
Am I right in assuming that the cavity gap won't be perfectly even throughout- so it may be 83mm at the point he drilled, but 1 meter along it could be 79mm or less??
Tell their surveyor that you yourself measured the cavity and to the best of your knowledge the average gap is 79.8mm. :P
Indeed, the pointy bit is the gable end.
A single measurement is not at all reliable or indicative of the cavity as a whole
And surely the grant is for the house and not individual walls? Cant the walls be averaged out?
If you don't have the actual details of the conditions of the grant, then I would suspect that his is a dubious attempt to not do the work, or get more money from you.
Come to think of it, is drilling the wall to check cavity width actually standard practice? I would have thought that a visual check for actual cavity construction, and possibly along with an approximation of cavity width is the norm. I've never heard of an invasive test being done for insulation work :roll:
Can't the walls be averaged out? Too simple sir!! And I believe an invasive test if the normal, indeed the only way of checking the depth and condition (in case they have been pre filled!) of the cavities.
