- Joined
- 1 Jan 2009
- Messages
- 254
- Reaction score
- 2
- Country
why even justify him with a response BAS, he is obviously trolling at this point.
Most electronic 'transformers' used for ELV lighting are more akin to SMPSs, capable of delivering a stable output over a range of input voltages, so the simple model of a fixed resistance load goes out the window.
if they are SMPSs, capable of delivering a stable output over a range of input voltages, how could you dim them?
They are indeed independent, but surely such independence would require a separate control signal if the output voltage were to be variable, otherwise the PSU would react to variations in supply voltage by maintaining its stable output voltage.
You've been doing 2330 for 2 years and you don't know the relationship between volts, amps and watts?![]()
That's my point - ELV lighting supplies don't have such a control. If using an external dimmer to lower the RMS voltage causes them to lower their output voltage then they aren't proper SMPSUs....Indeed so. There must, of course, be two controls. One is a voltage standard against which the output voltage is scaled. That could be a zener diode. The other is a voltage proportional to the output voltage required. That could be from a variable resistor.
You could, of course, build two circuits in series, one to control the maximum output voltage and the other to scale it according to the setting of a knob. Practically, both would be combined in one integrated circuit. Nevertheless, buried in that circuit would be two feedback control systems.
liampope:
1300 watt divide 230 = 5.7A
1300 watt divide 240 = 5.41A
the more voltage with the same current is LESS amps as there are more volts to divide the amps by!
I wasn't aware that a stable output voltage from a varying input voltage was a requirement of a switch mode PSU.
Of course it does - if it didn't then a directly connected incandescent lamp would not dim.Anyway, a modern dimmer doesn't vary the voltage to a load (be it a lamp or transformer),
It could be, but is it?Instead, PWM is used,
.so a SMPSU would be able to look at the mark/space ratio of the incoming PWM modulated AC mains, and approximate this to the required output on the ELV side for the lamp.
In other words the voltage is reduced.I suppose you could argue that if you approximate the output of a PWM dimmer to an RMS voltage, you could say that the output voltage is being varied. However, as the dimmer can only turn it's output on and off at varying speeds and durations, the peak voltage at the output will still remain the same, and the dimming is achieved by only passing current through the load for a set period of time every 1/50th of a second.
It's not some semi-specious argument you could make - the RMS voltage is reduced, and that is an indisputable fact.I suppose you could argue that if you approximate the output of a PWM dimmer to an RMS voltage, you could say that the output voltage is being varied.
Cool - so it could be done - you could build an ELV supply which offered both stability of output in the face of variations in input peak voltage, and the detection of the waveform being chopped to signal dimming.Integrated circuit controllers for ELV convertors for TH lamps now have these characteristics and far more! Soft start to limit the inrush current of cold lamps, short circuit shutdown too.
Have a look at this typical Halogen Convertor Control IC Data Sheet
