need to bridge gap between bottom of wall and new skirting
  • Thread starter Thread starter woodworm2009
  • Start date Start date
Status
Not open for further replies.
His DPC question has been answered in his duplicate thread.
You could mix some sand and cement together (4-1) and pva the wall and throw the muck on to the wall (when pva is tacky) with the top (back) of your trowel every 400mm annd leave it to pick up then hold a piece of wood (2x1 x 36" long) and gently with a sawing action hold it flush to the wall and scread off your muck so it finishes flush with the wall. leave it to firm up them drill thru your skirting into your "screeds" then take away your skirting and put a masonry drill into the holes in your screeds and drill into the brickwork and insert brown plugs and then fit skirting, screw it in and the screeds will hold it flush to the wall. Fill in above skirting as necessary.. Good Luck. :wink:
Status
