Hi all,
Me and my girlfriend have just bought a new flat (our first!) and it's second (top) floor. There is a dripping thin white pipe causing puddles on the ground floor patio, and unsurprisingly, they've asked us if we can do something about it.
The pipe is located on the outside wall, about 2-3 feet under where the toilet is in the bathroom. It drips intermittently, sometimes not at all, sometimes a drop every 5 seconds, sometimes it's close to a continuous trickle.
After a lot of googling, I was going to replace the ball cock (and its washer) in the toilet, but after examining the toilet I don't see how this could fix the problem. The ball cock is correctly positioned, and even if the washer's old, I don't understand why a dodgy washer on the inlet pipe to the toilet cistern would result in dripping water on an external white pipe. I've even held down the ball cock to let water go into the toilet overflow, and it doesn't affect the external white pipe, the water just goes straight into the toilet - so is it even serving the toilet at all? What do these mysterious white external overflow pipes normally connect to?! (Really exposing my ignorance here...)
I also have a condenser boiler in the adjacent kitchen, and after bleeding the radiators the pressure went down from 1.6 bar to 1.3 bar (I do know how to raise it again if needed), and I wondered vaguely if that could affect it, but no change (and it's definitely not the flue vent).
The other mystery about the flat is I have *no idea* where the cold water tank is. It's a conversion of an Edwardian terrace into two flats and a shop, and we have access to a loft over the lower level of the flat, but all the old water tanks in there are empty and out of use (which baffled me when I first went up there!). There is also a raised level of the flat (it's split level) with roof space over it, but there's no access hatch for there. Logically, I guess it must be over us somewhere, but surely it can't be permanently sealed!? Anyhow, I don't think the white overflow pipe is connected to the cold water tank, and it's too low down for that.
Yes, I could call a plumber, but since it's not an emergency, I thought I'd find out if it's anything simple and obvious. Any ideas? I mean, for a start, could anyone explain how these little white overflow pipes normally link to the toilet plumbing?
Any help very much appreciated
Joe
Joe
