Forgive my question. I am confident that i know the answer but would much rather check first.
I am about to move into my first house which has a concrete floor down stairs and not enough sockets because of its age (1955 - Council). As far as i have been able to determine from this site and others, i am able to modify an existing ring to add more sockets without needing to get the work certified.
However in the wiki has an entry which has concerned me.
[code:1]At the time of writing (April 2006), the following work was classed as not needing notification to LABC:
1. Work consisting of -
(a) replacing any fixed electrical equipment which does
not include the provision of—
(i) any new fixed cabling; or
(ii) a consumer unit;
[/code:1]
Does this entry mean that i can only modify an existing circuit if i don't add any new cable?
The second part of my post is regarding the chasing of said cables. I am aware that the safe zones are within 150mm of the corner or the ceiling as well as horizontally and vertically from any socket/switch. I also get the impression that the sparks on here dont much like horizontal chasing (im guessing from a wall stabilty point of view?).
With my livingroom i was planning on adding two gang sockets in each chimney alcove as well as 2 gangs on the opposite wall totaling 6 for the whole room. My plan for the alcove sockets was to drop from the ceiling to the first socket, and then chase horizontally about 2ft to the next socket and then go back up to the ceiling. While in a safe zone, would you consider this acceptable?
Would i be better to have the two gang sockets next to each other, meaning that the safe zone would essentially be one vertical area twice as large as normal and run a single chase in this zone.
Thanks for any replies, i have tried to find what i am after in the search but i couldn't be sure without asking myself.
[/code:1]
