The German Schuko sockets are not allowed in the UK as reversible and that means the only existing socket which is not already on decline would be the Australian one.
Apart from the shutter problem, this existing one would be OK, as it is polarised:
As is the plug:
which will also go into Schuko sockets. Schuko plugs won't go into the Type E socket of course.
A complete redesign so that every country has to have new plugs & sockets would avoid any problems of apparent favoritism if a system with some degree of compatibility with existing systems was used, and it seems to me that an in-line design (i.e. 3 pins in a row) would be good, as that would mean low-profile plugs - a benefit for portable equipment, and would be appreciated by anybody who has ever trodden on a plug.
Sockets with an angled entry would allow such a plug to lie almost flush against the wall thus needing less clearance behind appliances.
The spacing and pin sizes/shapes could be chosen so that no existing plug known to man could be inserted.
Subject to how any shuttering works, compatible 2-pin plugs for DI appliances could be made.
There are smaller fuse form factors than BS 1362, so a low-profile fused plug could be made if this was required.
If ring finals are to go then RCD socket outlets providing downstream protection, like some US ones do, would be a useful option.
There's no reason why MCBs have to look like the rail-mount CU ones we are familiar with - you can already get panel-mount ones which look like rocker switches, so a visually acceptable flush mini-panel could be made which would suit any room - maybe different sizes, 6/10mm² incoming capable and it distributes 1 or more lighting circuits and 1 or more socket circuits to that room.
