Hello
For some time now i have had Brown silty water coming from the hot water taps whilst the boiler is on.In addition the boiler or pipes makes a loud Banging sound.Also when the radiators / heating is turned off but hot water on the upstairs rads still heat up?? when the boiler is switched off completely and the hot water run the brown water eventually clears.
I have checked the expansion tank and there is brown sediment sitting on the bottom, i tried draining the system refilling and bled the rads but nothing has changed.
Does anyone have any ideas??
thanks, craig
thanks, craig
