Re-siting toilet problem
6 Nov 2008
We want to fit a close coupled toilet against a wall but our existing waste outlet will not allow us to do this. The outlet comes up from the floor then bends 90 degrees into the rear of the pan. Due to this we can only have a low level toilet. Is it possible to rectify this??
Cheers
build a false wall or use a swan neck pan coupler.
but some measurements would be nice.
A back-to-wall close couple pan set may provide you with the solution - plus you'll not see the wastepipe afterwards.
Mine does too - installed one of these http://www.wickesbathrooms.co.uk/pottery/toilets/blend-cc-toilet-cistern-and-soft-close-seat which cost £250 and not the price on the website. Worked a treat. You may find something similar.
Edit - not 300mm though!!
hows he going to fit one of them if the end of the pan connector is 175mm from the wall, and his floor waste is 300mm
Was unaware that is was 300 when I posted it originally, hence the edit.
Im guessing my only option really is to build a unit to fit the new cistern against. Ideally wanted it against the wall to give the room a bit more space
