Installed a new vanity unit yesteray with a monobloc tap which has a pop up waste operated by a small level at the back of the tap. Had a small leak on the connection where the level mechanism with the ball on which goes into the basin when the tap was left running and the trap filled up. Is there any reason why this happened?, the nut was fully tightened . Did manage to seal it with some PTFE on the threads but surely this should not be required.
