Hi, I'm new here, so please bear with me, because I might be off the mark.
I've searched the forums but can't find exactly what I want
I want to build two raised beds, one about 60 cm high and one about 1m high, so that you can build some seating against it and use it as a back rest. Each is a relatively small area, about 2x3m for the taller and 2x1.5m for the shorter. They're more to separate the areas of the garden than to retain large amounts of earth.
I want to create a clean mediterranean look, so was hoping to use concrete blocks and rendering them. I know I need to ensure correct drainage and line the inside to prevent water seepage.
The soil is heavy clay. I have already dug and filled foundations around 350x200mm for the smaller wall and I hope this is large enough given the small amount of soil in the bed. For the taller wall I am a little wary. Do they need to be bigger than this and do I need reinforcement of some sort? Are heavyweight concrete blocks suitable and what size should I use?
Any advice gratefully received.
